Home > Technical > Diff Lock light not coming on
jst
Hello, after some advice if anyone knows or has come across this before.
2010MY 2.4 Puma
Diff lock light in dash doesnt come on.
Diff lock def working and engages.
Have tried the plug on top of the t box and its all clean and good contact.
Do the switches fail? it is a push to make or break? does anyone know? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #738221 2nd Nov 2018 6:14pm
It may be an adjustment issue (switch not screwed far enough into the transfer box front output housing) or it may be that the switch is gummed up. I cant't remember if the switch is pressed or released when the diff is locked, but whichever it is it will make contact when locked.
If you short the switch wires the light should come on. If it doesn't, it's not the switch.
Post #738233 2nd Nov 2018 6:52pm
jst
Will take a look. Is the switch a later model for puma or same style as tdi ones with spades on top? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #738239 2nd Nov 2018 7:28pm
NickMc
Does it come on after a little bit of driving when it’s engaged?
Post #738252 2nd Nov 2018 8:05pm
jst
no, doesnt come on at all. but diff lock engages in and out smoothly and quickly. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #738297 2nd Nov 2018 9:57pm
Different connector on late vehicles.
Post #738325 2nd Nov 2018 10:46pm
landy andy
Pressing the plunger in on the switch operates the light. The switch can be screwed in further to adjust when it operates. So possibly yoursjust needs adjusting.
Post #738334 3rd Nov 2018 4:38am
VVS210
^^^ what he said Thumbs Up
Post #738356 3rd Nov 2018 8:33am
dorsetsmith
also make shore wiring is ok right side transfer box i.e earthing on ring tags 6mm bolt sun time get forgotten if box has been out for clutch or output drive shaft
Post #738376 3rd Nov 2018 10:52am
AndrewS
This is a great site Thumbs Up a wealth of knowledgeable people willing to help and give useful information.
Bow down Bow down Bow down Bow down 130's have feeling's as well you know Smile
Post #738377 3rd Nov 2018 11:22am
jst
Thank you on all, will take a look Monday and report back. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #738435 3rd Nov 2018 4:53pm
jst
Took it all out today, bridged the wires and dash light works, plunger is defunct on switch, no connection being made so replacement on order. Thank you for help, accessed from top in the end, at least I could see then!
Am I right in thinking the later style ones you just screw in tight and are non height adjustable? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #739437 8th Nov 2018 11:00pm
ashtrans
Site Sponsor
Hi James,
yes no adjustment on the later ones,
if you have to you can swap the thick ali washer for a thinner one,
Dave Dave
Post #739460 9th Nov 2018 8:21am
jst
cheers Dave,good to hear from you.
parts arrived today, as it happened i needed a thicker washer to avoid light being on all the time with diff in or out. fitted and sorted, thank you all. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #739596 9th Nov 2018 10:16pm
