Home > Maintenance & Modifications > Socket size |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1766 |
a bi - hex ring spanner?
28th Oct 2018 9:24pm |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 |
Ta didn’t think of a spanner, will give it a bash 1990 200tdi conversion 90
28th Oct 2018 9:34pm |
No problem, from memory they shear at a very low torque anyway
good luck! Keith |
28th Oct 2018 10:39pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
I have a Clarke Torx set, https://www.machinemart.co.uk/p/clarke-trx...it-set-29/
You;re not a million miles away - you can borrow if you need. Bought it a few years back, don;t use it very often, but mighty-handy to have around Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
29th Oct 2018 11:34am |
Thanks for the offer, I swing a bi hex spanner off it and see if it goes, will keep you posted thanks again 1990 200tdi conversion 90
29th Oct 2018 5:35pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1204 |
The inverse of torx are marked E.g. E8, E10 etc. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
29th Oct 2018 10:40pm |
TORX RING SPANNER
30th Oct 2018 8:20am |
