Home > Maintenance & Modifications > Nugget Stuff replacement air filter box |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
I took everything out without removing the wheel or arch liner. I do think you could get to the rivets if you turned the wheel hard right, there is room.
30th Oct 2018 2:33pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20566 |
Ah yes, you may be right there. KEEP CALM AND Drill ON
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
30th Oct 2018 6:18pm |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 |
Revival of this great write up in hopes some great mate can guide me through the LHD puma air box removal. I plan to drill the rivets from underneath as well as pull the cowl. But all I hear is nightmare stories on removing it without breaking it or cutting it up. Some guide would be welcomed!
9th Oct 2021 8:18pm |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
No need to drill out anything on a LHD car.
Inside the wheel well there are three bolts that hold the steel plate underneath the air box in place. Remove those and from beneath the car you can pull down on the plate to release it from the air box and remove it from below. Then all thatโs left is moving the air box horizontally to release the final two pins from grommets. Then itโs a Tetris game to get the box out. Take it easy and you wonโt even scratch the ac line. Click image to enlarge Click image to enlarge Roaming around ๐ณ๐ด๐จ๐ญ |
9th Oct 2021 9:17pm |
Ok so whatโs the key to the Tetris game? Hoping to try this tomorrow
11th Oct 2021 1:40am |
