Home > Maintenance & Modifications > 110 Double Cab tailgate mods. |
All Terrain Member Since: 22 May 2011 Location: Poole, Dorset Posts: 92 |
Hi All,
New here and looking at buying a 110 DC but have some tail gate questions. Is it possible to convert the tailgate to a side opening as opposed to the drop down? Would this be done with just regular SW rear door hinges? Any suggestions then on mounting the spare wheel onto the rear door? Would a Swingaway be the best option? Also reading the other thread on wheel carriers does the rear door on an ifor Williams foul the tyre even with the carrier open? Look forward to hearing your replies. Cheers, AT |
22nd May 2011 8:40am |
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 |
I have done this mod and used the bottom 2 hinges from a CSW door.
Click image to enlarge Click image to enlarge Click image to enlarge I wouldn't want to hang the wheel off it, I already had a swingaway carrier so I kept that. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2002 Defender 110 DC Last edited by ben_j85jty on 26th Dec 2011 9:21am. Edited 1 time in total |
22nd May 2011 9:44am |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
Has anyone done this with a 130? 130 crew cab
98 V8 Disco |
22nd May 2011 3:25pm |
Looks good!
How did you latch the non hinged side? With the original drop down catch? Thanks for the info! David. |
22nd May 2011 8:41pm |
Yep,
Just used the standard latch, it was easier and it's how the rear wheel carrier closes as well so it works on both counts. I removed the bottom hinges, and the tailgate closure "ring" from the side the hinges were going on. The exposed tailgate was not painted so if your looking for a really tidy finish count on respraying the tailgate. I touched up the areas an I am happy enough with that. HTH Ben 2002 Defender 110 DC |
22nd May 2011 10:14pm |
Thanks for the info Ben. Very helpful.
Cheers, David |
23rd May 2011 10:06am |
Blackwolf, useful info too, thank you.
I see you are local as well! Cheers, David. |
23rd May 2011 1:02pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
AT
Just looking at this months LRO and the white 11 reg defender 90 in the Exmoor Trim advert has a side opening tailgate - using 3 hinges. Looks good. Here is a link to the picture on their site http://www.exmoortrim.co.uk/index.php/cata...l?sef=hcfp Bob |
24th May 2011 12:41pm |
Cheers Bob, that does look good. Funnily enough I have that issue of the mag and it passed me by!
Hinges have arrived today, swing away has arrived too, just need bolts and the actual vehicle which I pick up on Tuesday. Will post some pics once the conversion is done. Thanks again! David. |
26th May 2011 2:05pm |
David
Pic's etc will be good, this is a mod I am considering. Bob |
26th May 2011 5:57pm |
Ok Bob sounds good. Will post asap.
Cheers! |
26th May 2011 11:17pm |
Picked up my 110 DC yesterday and I have already amassed the necessary stuff for the conversion.
Ben, just wondered if you had any tips for getting the holes aligned correctly for drilling as i assume there is little or no adjustment once drilled? Cheers, David |
1st Jun 2011 2:51pm |
I fitted the hinges with all the tailgate mechanism still in place, that way the hinges close it to the original position.
I also looked at the positions of the holes on a regular CSW and tried to fit it the same. 2002 Defender 110 DC Last edited by ben_j85jty on 26th Dec 2011 9:22am. Edited 1 time in total |
3rd Jun 2011 6:54pm |
Cool, that's what i figured but thanks for the confirmation.
3rd Jun 2011 7:59pm |
