Home > Maintenance & Modifications > standard to XS spec. Cost for upgrade? is it worth it?
Paulcmccormack
United Kingdom 2010 Defender 110 Puma 2.2 CSW Zambezi Silver
On the look out for a defender to replace a selling mistake.
I have my eye on a lovely car, but it's the standard 7 seat station wagon. not the XS spec.
I was wondering it there was any consensus on the cost and worthwhile of upgrading a standard model to an XS spec.
Central locking (easy and about 50 quid plus faf time)
Partial leather seats. can get new leather upholstery for a few grand that makes it better than the XS
Aircon? expensive and probably impractical
Electric windows.. not sure?
Heated seats. About 150 for a kit.
Anyone done any XS apec upgrades and is it worth it or should i keep looking for the right car?
Paul
Post #736611 25th Oct 2018 6:58am
I think you've picked up all of the obvious bits. Other details include the Brunel grill and headlight surrounds, heated windscreen, clear front indicators and I think the cubby box lid is different.
Whether it's worth it or not really depends on what you're happy with and whether you're trying to build a faithful replica or just get the bits that you want. All of the changes can be done at a cost, but come resale time you won't get your money back. On top of that, most that want an XS wouldn't settle for a conversion, even knowing it's a relatively easy job to do.
For me, the biggest benefit of an XS was the A/C and heated screen. Darren
Post #736618 25th Oct 2018 7:35am
Caterham
not sure what about ABS, alloys and suspension?
Post #736619 25th Oct 2018 7:39am
Paulcmccormack
Heated screen can be done for about 250 all in. It's fiddly, but possible. say 300 for the professionals.
Boost alloys are about 600 second hand (ish)
ABS you've no chance to upgrade I assume.
It was more a thought process as found a lovely non XS with the right look.
Post #736623 25th Oct 2018 7:49am
Ah, good point about ABS, which also brings with it traction control. Wheels are the easiest thing in the world to change. I don't think there's anything special about XS suspension above a regular station wagon. Darren
Post #736624 25th Oct 2018 7:50am
Caterham
in terms of 110 I thought the xs has HD suspension (probably just springs), but then how about anti roll bar?
Post #736625 25th Oct 2018 7:53am
The HD springs are to offset the weight of seats and passengers but that doesn't change with trim spec. and would also apply to other station wagons.
Anti-roll bars originally used to just come with alloy wheels but I'm pretty sure they were later fitted to all passenger carriers (as opposed to pick ups and hard tops). Again, a very easy addition if starting with a base vehicle that doesn't have them though. Darren
Post #736628 25th Oct 2018 8:09am
Stacey007
I don't know what the standard car is missing from an XS
You seem to have most covered and an easy fix.
The big ones would be Air Con, ABS, Traction? I would miss the Air Con in my Black 110 especially on the european trips. It's even good in Good old British weather if your out and get wet to demist all the inside.
Everything else you can add and change to the spec you like such as seats, heated seats, cubby box, carpets etc
If you will not miss A/C and the car is right you can easily make it your own
Post #736641 25th Oct 2018 8:54am
geobloke
I too have a TD5 110 CSW non-XS and have thought many times of trying to upgrade to ABS and TC... It is just not worth it.
The easiest way would be to get two axles from an XS spec'd wrecker as the axles ends and brakes are different. The piping and wiring wouldn't be much of a problem, just fiddly.
I came to the conclusion that if you want TC then it'd be way cheaper and easier to buy a set of Ashcroft ATB diffs and you'd be better off as the Defender TC is a bit... agricultural... Coupled with a set of BFG AT KO2s and you'll have a very capable vehicle. Plus you won't go through brake components quite as often..
As for the ABS part... Took a skid pan course and learnt to cadence brake properly. Think it cost about £100 and has saved my life too many times to count.
Brunel silver paint in a rattle can is an easy and cheap upgrade for the grille and headlight surrounds.
Previous owner retro-fitted AC at about £4k fitted as he travelled through France a lot. It's a good OEM spec'd kit, but I have never used it, not once. The condenser mounts rusted away a few years back so removed it when I installed a full sized intercooler. Have considered converting the AC fan and ducting to an additional heater system linked up to an eberspacher heater...
I did the (Puma) XS half leather seat up grade, keep an eye out on eBay as I got mine for £200 incl heaters, then bought the proper switches (£20) and the loom from mobile centre as I was feeling lazy. The Puma seats a re a superb upgrade on the earlier version of the seats.
The spot light loom I got as a kit off eBay too incl lights, relay and proper switch £150 all in.
Missing the heated screen and every year I wished I had one... Still not justified it yet.
Cubby box is a Mobile storage systems one and is leagues ahead of the LR XS version.
It is likely that the XS models came with running board steps too.
All in all... The cheaper mods are well worth it. The rest would be nice but I have not really ever thought "damn, i wish i had TC as I will never get up that hill without it"...
Post #736726 25th Oct 2018 5:32pm
Grenadier
I suppose the key question is is this lovely, right look non XS that much cheaper as to make all the upgrades, faff, time etc worth it? Have you ‘done the math’? If there’s a big difference and a saving after all the mods, why not? Indeed bar AC I think non XS is a great start point for a project, if that’s your eventual aim. If, however, you would just turn it into an XS, then perhaps just wait. Mine is non XS, has all the mods you mentioned (including retro fitted AC), plus other extras such as Bowler wheels, Recaros, soundproofing with Carpet on top, Focal speakers etc. Better value than if I started with an XS. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #736728 25th Oct 2018 5:43pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
XS version good bits for me;
Heated seats
Heated windscreen
Everything else is a waste or there to ponce up an agricultrual vehicle.
It isn’t worth the extra money imho
Post #736915 26th Oct 2018 5:41pm
Badger110
P.s. i’ll Sell you an air con set up if you like Mr. Green
Post #736916 26th Oct 2018 5:42pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
I was quite lucky with my td5 county spec (non xs) so came with electric windows, central locking which was standard on county trim + air con and abs/traction control fitted as options obviously from new. No heated screen or seats though.
I added the heated front screen and think that is probably one of the best things to have on a damp cold or icy morning in any car. Not bothered about xs heated seats but can see that it's a luxury on a real cold day! The air con is handy and adds comfort in summer but not hugely necessary in this country but glad it's there. The abs and traction control is a good safety feature
Mike
Post #737245 28th Oct 2018 4:14pm
