![]() | Home > Puma (Tdci) > 2.4 engine |
Keffer90 Member Since: 12 Dec 2017 Location: Leuven Posts: 40 ![]() ![]() ![]() |
Just got the bas news my td4 needs a new engine !
lost 70% compression on cilinder 2 and 3 1 and 4 are fine not sure what to do now rebuilding mine, getting a rebuild one or a new crate engine where can I get a good engine from ? maybe considering a second hand one any tips for me ? thx |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
Try;
https://www.ivorsearle.co.uk/ Peter |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1676 ![]() ![]() ![]() |
The best to deal with in my opinion is Turners
https://www.turnerengineering.co.uk/Mobile...02x3005731 |
They either spin the number 4 bearing or the rockers break away in the head. Injector faults and failures leading to failure.
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
I know where’s a good one going if interested localbreakers think it had done 75-80k 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
Had to replace my 2.4 tdci engine at 105000 miles earlier this year.
Best deal for a new stripped engine + OEM turbo + gaskets was from M&D engineering. |
Bergos Member Since: 08 Aug 2015 Location: Somewhere in Portugal Posts: 95 ![]() ![]() ![]() |
I am just wondering... How is this possible that those engines make hundreds of thousands of miles in Transits and fail after 100k in Defenders... Bergos
LR Defender 110 HT 2007 (2.4 Puma) https://www.facebook.com/LR.Wanderlust/ |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
Well, I know for certain my airbox doesn't seal around the filter., and I suspect many others dont, which will do nothing for engine life. 2007 110 TDCi Station Wagon XS
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 ![]() ![]() ![]() |
When I was serving, a common mod was to cut a bit of inner tube, couple of inches thick, and wrap it round the base of our helmets to prevent the helmet covers fraying when in contact with rock/walls etc. I thick some army surplus stores made them as well. Something similar would work well as a supplementary seal I'd think.
![]() Click image to enlarge That's not me, BTW ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Following on, is it possible to recondition an engine (2.4 in my case) without taking it out? Monsieur Le Grenadier
Because it’s a different engine in the Defender than your everyday white van- the bigger version RWD transits have the same problems. |
the engine had 160000 km
at 135000 km the timing chain broke and i replaced it and then the turbo went and clutch only to find out there was a loss of compression ![]() |
Did it break the rocker carrier bolt? Out of interest did it get towed at any point when the chain broke?
well I am finally starting on my defender
bought a good 2nd hand engine and goingto drop it in soon Im back in the mood to get my defender fixed ![]() |
