Home > Technical > LT230 intermediate shaft leak
How many miles before the LT230 intermediate shaft started leaking?
It's not leaking yet!
8%
 8%  [1]
less than 50k
0%
 0%  [0]
between 50k and 100k
25%
 25%  [3]
between 100k and 150k
50%
 50%  [6]
between 150k and 200k
8%
 8%  [1]
More than 200k
8%
 8%  [1]
Total Votes: 12
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
We all know the intermediate shaft on the LT230 is prone to leak on its open end at the front of the box, sometimes the casing itself is worn out, but I wonder, how many miles before it started leaking? (and if it's not leaking, please indicate your mileage).
For me, the 90 is dry like the Atacama desert at 60k, whereas the Discovery is leaking a pint every thousand miles at 182k...
Thanks! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #735036 16th Oct 2018 12:51pm
Puma - now at 230k miles and not leaking. It is the second t-box (original replaced at 150k miles because it whined but that wasn't leaking either). The current t-box was a pre-owned one with an unknown number of miles on it when I bought it, and it too is now whining but not leaking.
Disco2 - now at 210k miles and not leaking, at least not from the intermediate shaft.
Post #735051 16th Oct 2018 1:36pm
oneten110
Ashcroft do a modification on the T box. Fitting a steel sleeve into the casing which obviates the problem with the shaft wearing away the casing and promoting incontinence
Post #735534 18th Oct 2018 2:48pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
The Wife's Defender is currently at the garage having the transfer case leak sorted. 62,000 miles.
Post #735600 18th Oct 2018 7:22pm
