Home > Puma (Tdci) > Broken front axle ?
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Broken front axle ?
I Was driving back from town this afternoon and the steering was gradually pulling to the left more and more to the point I thought I must have a flat tyre. Pulled into the farm to take a look and the near side wheel was off at a angle , looked underneath and the entire axle housing has split !
Pics attached , I can only imagine that’s a new axle ?!
Post #735537 18th Oct 2018 3:55pm
Looks like the weld has failed. Surprised Shocked
Very dangerous indeed and I'd say you were very lucky there both yourself and mechanically. WeWillWin🇬🇧🇺🇸
Post #735541 18th Oct 2018 4:09pm
Bluericky
Yes very lucky ! It’s bang on the weld
Post #735542 18th Oct 2018 4:14pm
jst
That's not good. How many miles, usage?
You can get that welded back up, prob in a jig. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #735545 18th Oct 2018 4:19pm
jst
As there not loads of oil everywhere but the area is damp i guess its been leaking there for a while. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #735546 18th Oct 2018 4:20pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
There was a recall for that which involves either adding brackets or replacing the axle:
http://www.defender2.net/forum/topic33029.html
But this was for MY11/MY12, yours is a MY09, so that's worrying indeed! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #735548 18th Oct 2018 4:31pm
dorsetsmith
Recall Action P047/048 Front Axle Case
have read below
Post #735549 18th Oct 2018 4:34pm
Bluest
That is serious indeed. Glad you recignised the warning signs and pulled over. 2007 110 TDCi Station Wagon XS
Post #735550 18th Oct 2018 4:35pm
Bluericky
It’s a 2009 with 130k on the clock , I never abuse it , my wife calls me Captain Slow !
Just can’t believe that such a major mechanical part could fail !
There was a slight leak from the joint to the right which ironically I rung up about this morning . The local specialist booked it in for the 29th but I guess it will be in for a more major repair !
What do you all think , a whole nearly new axle or a brand new casing ?
Post #735580 18th Oct 2018 7:21pm
LR90XS2011
I'd say you were extremely lucky to find that before it failed completely which could be a disaster.
a second hand old axle to fit your bits to would be relatively cheap to sort, especially if you can wield the spanners DEFENDER 90 TDCI XS,
Post #735583 18th Oct 2018 7:30pm
MK
Abysmal quality Puma 110" SW
Post #735655 18th Oct 2018 11:20pm
NickMc
I would contact Land Rover as it’s a known problem and see if they will replace it! It’s not a wear and tear item that’s a manufacturer defect. That is scary Shocked
Post #735662 19th Oct 2018 8:02am
hank
Wow! Worrying
Post #735992 21st Oct 2018 7:03am
Bluericky
I’m going to crack on and replace the axle. I’ve got three options and would appreciate opnions as they differ wildly in cost . All I need is the axle casing , I believe the part number is TAJ500090
Here are the options
1. Genuine new Land Rover @ 1600 plus vat
2. OEM new @ 700 plus vat
3. Reconditioned genuine @600 plus vat
OR
a complete second hand axle from a low mileage post 2013 truck ?
The first option is very nearly out of the question !
Post #736349 23rd Oct 2018 3:46pm
miker
I'd still be trying to push it back on Land Rover...
Post #736351 23rd Oct 2018 3:52pm
