Home > My Defender > well ours tried to kill us today
NoDo$h
40 mph on a country road and "screeeeeeeeeeeeeeee........" as the car decides to lurch hard right. OSR wheel locked solid with no warning. Had it happened a few seconds earlier we would have been a bonnet accessory on a RRS heading the other way.
We'd only been driving perhaps a mile, but the wheel around the hub was warm to the touch, while the brake surfaces were cold. All points to a failed wheel bearing. Not what you expect for 27,000 miles.
Off to read my big boys book of wheel bearing changing tips Rolling Eyes
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #73489 30th May 2011 4:49pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
do you have any drive train mods, spacers.. etc?
Jack
Post #73494 30th May 2011 5:18pm
NoDo$h
Nope. Been bog standard from the day we bought her, fresh from the showroom. Only difference is that we're now running 265/75 BFGs which are actually marginally smaller in diameter than the factory 235/85 TRs (a whopping 2mm smaller in fact)
Jacked it up just now and it's got loads of play and is grinding like a barrel-organ monkey on speed. How the hell we haven't heard it is a mystery. Confused
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #73496 30th May 2011 5:39pm
Landie Boy
ohh :/ hopefully the damage inside isn't too bad Smile
Jack
Post #73501 30th May 2011 6:05pm
NoDo$h
With my luck at the moment I expect it's trashed Rolling Eyes
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #73503 30th May 2011 6:38pm
jst
that extra width tyre size is unlikely to be the main cause of premature wheel bearing failure. more lilley water ingress or similar or a bad batch.
i would use Timken for the rebuild and you may need a new stub axle when you are at it if the race has seized on (worse case - also a big hammer to get it off!)) Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #73663 31st May 2011 8:50pm
NoDo$h
Cheers James. Having a proper look at it today so will report back later. Thumbs Up
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #73829 2nd Jun 2011 6:42am
I.AM_a driver
Scotland 2002 Defender 90 Td5 CSW Oslo Blue
every time I've had a wheel bearing replaced, it's needed a stub axle too, and it's never something that anyone seems to have in stock when I have a problem.... Rolling Eyes Mark S
CONVOY for HEROES
www.facebook.com/convoy4heroes
www.lothian4x4response.org
Td5 90
Thread in 'My Defender' Forum
Post #74236 4th Jun 2011 5:27pm
jst
Exeter 4x4 always seem to have them when i need one! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #74250 4th Jun 2011 7:05pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
wow, good to hear you had a bit of luck and your ok.
if that was a busy A road at 50mph with on coming traffic......
Post #142271 28th Apr 2012 5:04pm
It's nothing new though... when I had my "new" 200Tdi 90 back in 1992, all 4 rear wheel bearings died within a year.
When I stripped them out there was hardly any grease at all in them. A friend in the trade who lives near Solihull and dealt with the factory on a regular basis back then, told me that they only use(d) a teaspoon of grease per corner on axle build up!
Probably not much more thesedays either.
Post #142295 28th Apr 2012 7:01pm
