Home > Technical > No air coming in cab without the fan on?
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Driving 475 miles today back from Scotland to Essex I couldn’t get any air to come in to the cab without the fan on? I’m sure that when the slider was over to the right fresh air from outside was sent in to the cab? Am I going g mad? Is it a common fault? Can anyone shed any light on how to fix it?
 2010 Defender 90 HT
The longer I live..... The better I was!
Post #734580 13th Oct 2018 9:21pm
Bluest
There is not much ram effect on Defender heater system due to where the intake is. Even worse if you have a snow cowl. So not much comes through with the fan off. 2007 110 TDCi Station Wagon XS
Post #734584 13th Oct 2018 9:44pm
Butchers Boy
I have the wing top air intake vents!
 2010 Defender 90 HT
Post #734589 13th Oct 2018 9:53pm
Balvaig
Could be that it has stuck in recirculation mode. You should here the flaps move when you shift your circled lever to the left.
Try sliding the lever left/right a few times.
Post #734620 14th Oct 2018 8:44am
Butchers Boy
Just tried that and can’t hear the flap opening and closing? Is it a dash out job? 2010 Defender 90 HT
Post #734623 14th Oct 2018 8:58am
ibexman
Open the window Whistle
Post #734635 14th Oct 2018 10:29am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Might be worth checking your bowden cable from the control lever is still connected and moving the lever on the blower unit;
Mine personally got a kink in the stranded bit and if I pushed it too far towards recirculate it popped the hooped end off the lever.
Edit: Just read that you can'y hear the flap working, so I'll expand a little. I didn't need to take the dash out, just unbolting the centre bit housing the radio and all the buttons etc so I could reach in, combining that with reaching up (which means you can only just touch the end of the blower lever. I will warn you though. It was bloody fiddly Laughing
Let me know if you need more help and I'll try take a few pictures if my descriptions aren't any good Thumbs Up
Post #734636 14th Oct 2018 10:41am
TriniDaddy
2008 Defender 110 Puma 2.4 XS CSW Arles Blue
Hello all and Happy New Year.
I'm having a similar issue with this part. When I put the selector to the right to open the vent it just bounces back. If you move the flap from the lever (2) however it's a bit stiff but it switches over and the selector stays in position.
Could it be as simple as a loose/snagged cable? Or do I need to replace it altogether? If the latter, what is the part number for this thing! I can't find it anywhere!
Also, in the manual it says there should be two cables. This is getting tricky...
 110 SW 2.4
IZUMI BLUE
Post #937938 16th Jan 2022 5:11pm
