Home > Off Topic > Plumbing help
Bluest
Plumbing help
Does anyone know how to get this type of plumbing fitting apart? Google suggests I just need to push the collar at the same time as pulling aoart, but this doesn't seem to release them.
 2007 110 TDCi Station Wagon XS
Post #734520 13th Oct 2018 2:40pm
lozza
push the green bit down
Post #734522 13th Oct 2018 2:46pm
Siwynne
Pair of pump pliers on copper resting on collar. Tap top of pump pliers gently to push the fitting off.
Post #734526 13th Oct 2018 3:31pm
Bluest
The collars already appear to be pressed down. Not sure about pliars and a hammer, the pipework is not that well supported. 2007 110 TDCi Station Wagon XS
Post #734527 13th Oct 2018 3:37pm
Sunshine
Push the copper into the fitting push / pull the grey collar into the fitting keeping it held in pull out the copper pipe
Make sure the water is drained of / pressure released first
Post #734528 13th Oct 2018 3:39pm
Bluest
I give up. I've pushed, pulled, squeezed and yanked to no avail. Might have to get a man in. 2007 110 TDCi Station Wagon XS
Post #734529 13th Oct 2018 3:52pm
Siwynne
Pliers perform the same as this clip or shifter. The o ring will be slightly stuck to the pipe. Support the pipework Give it a tap
Post #734530 13th Oct 2018 4:13pm
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
I have seen some like this before and I had to prise off the end of the white bit to get underneath and be able to depress the collar. Not saying these are the same, but it's worth looking at. If they are removable they have a keyway to get a screwdriver in somewhere. Otherwise they are permanent fit items and you will have to destroy the white bit and replace the whole thing after.
I am assuming the pressure in the pipe is zero? If there is any pressure, they won't release. V8 90...WIP
Post #734573 13th Oct 2018 8:39pm
Bluest
There is no pressure in the pipe, I drained it all down. It doesn’t matter if they get wrecked coming off as long as the copper isn’t damaged too much. 2007 110 TDCi Station Wagon XS
Post #734585 13th Oct 2018 9:47pm
landy andy
I’m a plumber.
As mentioned above. Push the fitting up onto the copper pipe, then hold in the grey lock ring towards the flexible pipe and pull. You will probably have to do this many times if it has been fitted for a long time, and in hard water areas can be a real job. If fitting isn’t required the hacksaw towards the pipe, through the fitting, and that will cut through the lock ring and release.
Often use adjustable spanner, with jaws open over copper pipe, wide enough that they can move along copper, butter smaller than lock ring to help with the on/off on/off on/off pushing pulling bit until it releases
Post #734597 13th Oct 2018 11:12pm
AMBxx
From recent personal experience when one of those pipes decided to become two (day before holiday Big Cry ), I'd say that you're not swearing enough. Twisted Evil
Post #734773 15th Oct 2018 8:35am
miker
They are a "simple" push fit, but looking at it I reckon that bit if green is either corrosion, or loctite that someone put in to seal a leak!
Post #734784 15th Oct 2018 9:27am
