Home > Tdi > Prop shaft |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1115 |
Anyone tell me the length of the rear prop shaft on a 90 300tdi .
11th Oct 2018 12:13pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
http://www.ep90.com/propshafts-ujs.html 1988 90 Td5 NAS soft top
2015 D90 XS SW |
11th Oct 2018 12:37pm |
Many thanks, mines 700mm and it's seems tight and rubber sleeve as spilt.
11th Oct 2018 12:43pm |
how much travel should it have on the shaft .
11th Oct 2018 6:55pm |
Just concerned about the rubber sleeve being spilt and looks like it been squashed.
11th Oct 2018 8:40pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8030 |
pull the sleeve off the wider part and check condition of the splines - are they corroded? i have not checked how long yours should be but if it fits and can be removed with the vehicle on level ground, not jacked and there is still 15mm or so further compression from the amount you need to compress it to remove it i would suggest its ok. Has the vehicle been lowered? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
12th Oct 2018 7:37am |
Thanks James the prop is nearly new, not lowered all standard.
The old was even tighter to get off . Can the transfer box be different length. Just thinking maybe someone fitted a none standard one. |
12th Oct 2018 10:23am |
How many miles has it done since fitting? Do you have 10mm or so compression as described above? Cheers
12th Oct 2018 12:09pm |
