Home > Td5 > Transfer Box Leak |
Gearboxes leak... not much you can do about it.
The solution maybe the factory drip and sound proofing panels; https://www.ebay.co.uk/itm/117-AWR5428-Lan...img][/img] https://www.landroverworkshop.com/diagrams...ly_52794#1 |
10th Oct 2018 1:04pm |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 |
Yeah, I appreciate the transfer box leaks but it would be good if it didnt. Prevention rather than catching it in a drop tray would be my preference but thanks very much for the link.
Cheers |
10th Oct 2018 1:18pm |
Of course, but as an immediate "there you go hunny all sorted now" solution the drip tray would give you the time to track the location of the weeping oil.
10th Oct 2018 1:36pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2229 |
From experience there are 3 common leak points from the LT230:
1. The inspection cover on the base; 2. The drain plug washer/threads; 3. The intermediate shaft seals (common and hardest to fix). Steve 02' 110 TD5 Double Cab Rebuild Thread |
10th Oct 2018 2:16pm |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 |
Finally got around to sorting the intermediate shaft leak 2 weeks ago and still all good...
Look here http://www.defender2.net/forum/topic61966.html Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
10th Oct 2018 4:58pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
My intermediate seal is leaking quite badly. It's a pain as it leaves the back of the truck covered with oil spots which dirt then sticks to.
Suppose I should summon up the enthusiasm to remove the t/box and change a £2 seal... |
10th Oct 2018 8:15pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
Mine is also leaking from the intermediate seal. Sprays oil up the back of the truck or the front of any trailer I happen to be pulling.
I have a feeling mine needs the full sleeving treatment however, as it's done 210k, dropped most of it's oil at least once (by a previous owner I might add), and whines like a banshee from 35-45 mph. So I really just need a new tbox |
10th Oct 2018 10:15pm |
