Home > In Car Electronics > Speakers |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20359 |
Depends on where you would like them? I'm assuming you mean factory locations?
If so upgrade to 130mm and they should just about fit. Many fit Focal, and are better placed to comment than me as mines not a TD5 and there is variations to the dash. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
8th Oct 2018 4:02pm |
shaun1968 Member Since: 30 Aug 2018 Location: Essex Posts: 65 |
Hi, unfortunately mine has nothing fitted at the moment, so effectively starting from scratch, its a 1986 90
8th Oct 2018 4:10pm |
Ah I see, shouldn't be too difficult.
Hopefully someone can give you some dash reference points for cutting your holes. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
8th Oct 2018 4:16pm |
V8Simon Member Since: 17 May 2016 Location: Prestatyn, Wales Posts: 147 |
I might have the dash panels already cut for 10 inch speakers on my old bulkhead if you wanted to use these rather than cut your own?
From memory (1990) it was a simple job to cut the required holes and I think I had a small spacer on the passenger side. |
9th Oct 2018 11:27am |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5808 |
In my Puma DCPU I have Focal tweeters on the dash and Focal 10cms under the dash (both like-for-like swaps), Focal 10cms in the headlining by the B Pillar, 14cms in the rear corner headlining and a Focal 2.1 20cm sub under the rear seats, all tied to a Kenwood Head Unit and full sound insulation. When I first used it, it actually made me smile. Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
9th Oct 2018 2:14pm |
