Home > Puma (Tdci) > Swivel seal vs hub seal
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Had an advisory from MOT - "front drive hub seal leaking"
So I looked at the wheel and it seems to me that the swivel seal is actually leaking.
Would the hub seal actually leak oil? As far as I can tell there is just a little bearing grease in there.
The swivels on the other hand seem to be filled with either oil or the one shot grease.
I have a 2009 (MY 2010) USW - questions I have are:
1) Can the hub seal actually cause leakage? or am I looking at replace swivel seal?
2) How can I ascertain if I have grease or oil in the swivels?
Any advice gratefully received
Post #733259 6th Oct 2018 9:21am
kmac
Pic
20181006_102429 by [url=https://www.flickr.com/photos/152440487@N03/][/url]
Post #733263 6th Oct 2018 9:32am
williamthedog
Swivel seal is the one that is shot.
Post #733295 6th Oct 2018 11:36am
williamthedog
Forgot to say, yours should have one shot grease in for that year.
Post #733297 6th Oct 2018 11:38am
Retroanaconda
The hub seals can leak, you usually notice when you have no brakes on one side as the disc gets covered in oil/grease.
Axle oil migrates along from the tube into both the swivel housing and eventually the hub, so you will get a mixture of oil/grease in both eventually. Does no harm really.
Post #733313 6th Oct 2018 12:44pm
kmac
Okay, thanks chaps. Now to get a swivel seal kit.
Already have the hub seal.
Post #733316 6th Oct 2018 1:05pm
