![]() | Home > Puma (Tdci) > Removing tow bracket |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6642 ![]() ![]() ![]() |
Dig out the fitting instructions and start at the end
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
Yep all the bolts that it goes into on a Tdci are captive on a Tdci. Soak them in something for a few days before you attempt it, if you snap one it can be a real swearing match
![]() Three along the bottom. ![]() Click image to enlarge ![]() Click image to enlarge |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
Thanks, does that include the ones that go up from beneath, the ones that hold the angle iron on?
Sorry, just re-read your post and you already explained! Not sure why you would need a thinner socket all are in an accessible place as far as I can see! |
If you have a Dixon bate style drop hitch the bolt head is very close to the uprights on the slider.
Oh, I see, I don’t, so no problem! Thanks again.
