Home > Maintenance & Modifications > Heated seat wiring advice |
Two elements perhaps? 12v feed for either...!
Have you got a multimeter to test the circuits? |
5th Oct 2018 7:37am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Waeco heatter kit?
They are two stage/heat levels controlled by the Waeco 3 way switch (off-low-high) 1988 90 Td5 NAS soft top 2015 D90 XS SW |
5th Oct 2018 7:45am |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 830 |
Not sure the make itโs in an exmoor seat but I think they have been retrofitted
5th Oct 2018 8:42am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
Earth, low and high.
Two choices, as suggested a two way switch for pre heat and constant. Or, wire to constant only like I did and have a 1 way factory on-off switch. To save you messing, I can check mine to let you know wire colour? If so, drop me a pm to remind me and I'll take a look for you. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
5th Oct 2018 9:58am |
Thanks everyone
Cheers Steve pm incoming |
5th Oct 2018 10:44am |
