Home > Td5 > Battery warning light |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Would be worth checking the charge voltage at the battery but anything under about 13.5v charge voltage is too low 2002 90 Td5 Station Wagon
3rd Oct 2018 5:49pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5844 |
Around 12.x volts. Something not right. I can see the volt meter dipping in time with battery warning light, 1999 Defender TD5 110
3rd Oct 2018 5:51pm |
I think the Td5 alternator is a 14v unit so 12v is way too low 2002 90 Td5 Station Wagon
3rd Oct 2018 5:52pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
You should get 13.5V at the battery, up to 14.1V when it's cold.
3rd Oct 2018 5:57pm |
Cheers for the replies.
When the battery light is not on i would normally get 14.5v ish volts. Would you expect to get a voltage output from the 13mm nut connector on the alternator with the brown wire disconnected & engine running? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
3rd Oct 2018 6:51pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Had this on mine....had to replace alternator
Then battery started to go so replaced that as well |
3rd Oct 2018 7:46pm |
This morning, about 3 miles into the trip to work, all well, no battery light. Then bing! on / off for the rest of the 1mile to work.
New alty to be ordered me think 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
4th Oct 2018 7:14am |
New Denso alternator ordered. Any tips for dealing with oil drain hose? 1999 Defender TD5 110
4th Oct 2018 12:42pm |
Good choice re alternator...LR ones (TD5) were denso.
Still got my old one and plan to get this refurbished. |
4th Oct 2018 3:31pm |
I was pondering the option of a Bearmach/Allmakes for a bit less, but 'charged' on and made the 'positive' choice of Denso. I have seen repair kits for them, get this done and tested followed by a repair. 1999 Defender TD5 110
4th Oct 2018 3:52pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5173 |
I would say its the alternator too, They do daft things when they start to go on the blink. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
4th Oct 2018 8:27pm |
tony.g Member Since: 25 Aug 2017 Location: uk Posts: 21 |
I got a Britpart alternator a few months ago and even after several hours could not get the thing to fit. Had to give up and got a Denso one from the dealers and it went in straightaway.
The aluminium casing on the Britpart one didn't look as fine and neatly cast as the Denso. |
4th Oct 2018 8:39pm |
Job done. New alternator on. The one I took off was an original LR one, so could be the original one. If so, its done 210,000 miles!
Fitting time around 2 hours. Lets see how the work run goes. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
7th Oct 2018 3:53pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2527 |
Good luck with the run to work tomorrow. Keep us all posted. Defender 90XS SW
7th Oct 2018 5:07pm |
