Home > Puma (Tdci) > Refurbished Injectors - Are they worth it? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4208 |
What can be refurbished on these types of very high pressure injectors? I genuinely don't know, not being sarcastic. Is it more than just spraying them with carb cleaner to get the dirt off? 2007 110 TDCi Station Wagon XS
3rd Oct 2018 5:04pm |
Big Harold Member Since: 09 Jul 2018 Location: nsw Posts: 71 |
We have these guys down in Oz.
They fit new needles that are ceramic coated. https://www.baileysdiesel.com/shop/bluepri...nder-2-4l/ Mark |
3rd Oct 2018 9:54pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
I've never had any luck with recon injectors... times have moved on since tdi days, but a lot of recon places haven't.
For Tdci 2.4 or 2.2 I would always use new - which will also have the correct calibration code to put into the ECU. No need to go genuine - just OEM. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
4th Oct 2018 11:55am |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Hi Porny, Many thanks for your advice. Without putting you on the spot can you recommend a good supplier to get them from? Ive seen prices for new ones ranging from £ 180 to over £ 400 per injector!!
Many thanks again. |
4th Oct 2018 12:50pm |
I can do you brand new OEM injectors for £155 + vat each (if buying 4)
This includes all new seals. Only additional thing needed is 2 new clamp bolts which are £8 + vat a pair You will need to get the injectors coded into the ECU once fitted and Pilot Learn redone. Fitting is easy - as long as the old injectors come out. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
4th Oct 2018 12:57pm |
Hi Ian,
PM on its way. Many thanks Steve |
4th Oct 2018 1:49pm |
keath Member Since: 02 Mar 2016 Location: Barwon Heads Posts: 5 |
If you don't mind me asking, where from? |
15th Oct 2018 4:28am |
Keath - from me. Drop me a PM if needed.
Regards Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
15th Oct 2018 11:27am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
I can vouch for Porny's work if needed
15th Oct 2018 3:45pm |
Hi Ian, Check your PM's. Cheers. |
11th Nov 2018 9:37pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Definately go new Ian at IRB can do them at a decent price circa 120-130 iirc 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
11th Nov 2018 10:29pm |
Ian @ IRB is Porny, above.
11th Nov 2018 11:25pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
Would you be able to quote part numbers?
Cheers, Peter |
12th Nov 2018 11:59am |
OldDD Member Since: 17 Jan 2016 Location: Ballaugh Posts: 53 |
Porny
I'd be keen to know more about the Injectors you offer - Can you pm me the spec please?? Do you have them in stock?? |
18th Dec 2018 12:38pm |
