Home > Technical > New Key
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
New Key
The battery of my 2014 Puma key fob has been flat for some time.
After replacing it, it no longer unlocks the car.
Can I use my BAS tool to reprogram the fob?
Jan
Post #732787 3rd Oct 2018 7:02pm
Have you tried pressing it multiple times fast and repeatedly? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #732798 3rd Oct 2018 7:36pm
Yannis
Tried that, I will give it another go but think the fob has been flat for some time.
*i have the new style fob with the silver bit down the side.
Post #732868 4th Oct 2018 9:09am
Balvaig
Going from memory, I think you have to put the key in the ignition, turn to position II, turn off and then press the fob lock button 4 times.
Post #732873 4th Oct 2018 9:27am
Yannis
Still no luck 😐
Post #732879 4th Oct 2018 10:02am
Martin
Site Admin
2015 handbook doesn't mention any procedure to re-pair the later style fob Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #732892 4th Oct 2018 10:45am
Yannis
I had a look in my hand book and as you say there is no procedure.
I had one of the keys replaced some time ago by the dealer and I wonder if they removed both fobs and just added 1 back
Post #732899 4th Oct 2018 11:08am
Balvaig
Worth double checking that you have the battery in the right way, and also perhaps trying another battery too.
Hope you don't have to pay Dealer to reprogram.
Post #732902 4th Oct 2018 11:34am
Porny
Site Sponsor
Remove the battery from the fob... hold down the lock or unlock button for 10 seconds.
Refit battery and then press the lock or unlock button 5 or 6 times and it should 'resync'
Worth a try before visiting a dealer or a good independent that has the kit for the later alarm set up. IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #732907 4th Oct 2018 11:52am
Martin
Site Admin
Just changed the battery in one of my fobs, and it was utterly unresponsive after.
Took battery out and followed Ian's advice above. With battery out, 10 sec press on a button, new battery in then pressed lock 6 times. Got a horn fanfare (...) as the door was open, then did a little dance.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #733056 5th Oct 2018 9:16am
Porny
Site Sponsor
Ha...
One of my first posts on here for quite a while... and I fix the site owners Defender lol. IRB
Post #733059 5th Oct 2018 9:51am
