Home > Td5 > Changing TD5 fuel filter |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1423 |
The auto purge will sort it
2nd Oct 2018 9:21am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 558 |
Leave the purge running for a few minutes, if you don't they can be a pig to get going again.
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
2nd Oct 2018 11:38am |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
I tend to fill the filter and put on...never had any probs with air in system.
2nd Oct 2018 2:37pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Fill filter before you put back on then do purge
Ignition on and press accelerator 5-6 times time engine management light comes on takes about 5-8 mins 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
2nd Oct 2018 4:10pm |
so in summary either works
2nd Oct 2018 4:26pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
I just put the new one in and let the purge deal with it!
2nd Oct 2018 4:29pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2778 |
That was what l wanted to know!
I always fill the filter with diesel but it’s a faff to do, and you have to have some diesel handy to do it. So if l can just fit the filter empty and wait for the purge cycle to sort it out then that will be great. |
2nd Oct 2018 5:10pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
Don’t do what I’ve seen someone do- pour the fuel out of the old filter into the new one
2nd Oct 2018 6:19pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I don't bother filling it. But does the diesel go from the inside to the outside or from the outside to the inside? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
3rd Oct 2018 6:01pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
Last time I filled it with injector cleaner as it had been running a bit meh... it fired straight up and ran fine since 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
3rd Oct 2018 7:51pm |
