Home > Puma (Tdci) > 2.4 MAF sensor plug
Bluest
2.4 MAF sensor plug
Due to circumstances I'd rather not discuss, I've slightly damaged the loom plug to the MAF sensor such that it won't latch on. The sensor is slightly damaged too but that's no problem to replace.
Are these available anywhere (please say yes!) and what tools would I need to replace it. If the plugs aren't available.any suggestion for a solution? 2007 110 TDCi Station Wagon XS
Post #731848 29th Sep 2018 2:07pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
The connector is available to buy
I believe it is part YPH900370
About £5
Post #731855 29th Sep 2018 3:46pm
NickMc
Pretty standard Ford/GM part complete with stupid red lock. In the connectors manual there will be a part number listed.
Post #731856 29th Sep 2018 3:46pm
kmac
See this thread - also available with pigtails to make it easier for you
http://www.defender2.net/forum/topic49422.html?view=next
Post #731858 29th Sep 2018 3:52pm
Bluest
Thanks all. Simtek, that sell the one with pigtails, is walking distance from my house. Who’d have thought it. Thumbs Up 2007 110 TDCi Station Wagon XS
Post #731879 29th Sep 2018 6:19pm
If you get the plastic connector off without damaging the pins it'll fit straight in the new housing. You can even sacrifice the old one if your replacing it, and no crimping needed either.
I wouldn't cut it off and then add another, anybody would permanently notice but then that's just me.
I avoid cutting the standard loom at all costs and would rather replace or extend where possible. WeWillWin🇬🇧🇺🇸
Post #731881 29th Sep 2018 6:25pm
