Home > Maintenance & Modifications > Puma Door Card Fixings |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3254 |
28th Sep 2018 8:57pm |
if you only need a few get them from your local dealer, they're not expensive and will likely be in stock.
MWC3136 for the sacs EZM500050 for the clips. MWC9918PMA for the large external black clip in the corner. (MWC9917 is the sac for it) Have the red bits come away from the door card? If they have then you're better off just buying a new door card as they don't glue well. New door cards are only about £50 from a dealer - and someone will pay £20 for your knackered one on eBay |
30th Sep 2018 12:06pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1623 |
If they’re broken on the door card get a short wood screw and screw it in the broken clip on the door card and the stud will slip right on
This video shows you about 2mins 40 in: |
30th Sep 2018 3:00pm |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 453 |
Thanks all for the help. very much appreciared.
Cheers Chris |
1st Oct 2018 8:05am |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
I bought an old one, drilled out the old yellow and red clips, and superglued them into my door card, worked great, then ditched the old card, tenner, plus the glue, and did both sides. |
1st Oct 2018 6:04pm |
