Home > Puma (Tdci) > Bubbling on wing mirror arms
galawaygreen
2010 Defender 90 Puma 2.4 XS CSW Galway Green
Hi just wondering my paint is bubbling on the wing mirror arms is this a commen problem and do you think LR would change them as the rus has not broken through?
Post #73090 27th May 2011 3:45pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Under warranty - Yes.
Post #73094 27th May 2011 3:56pm
BigRuss
Yes. I had mine changed a month ago under warranty. Russell
2011MY 110 XS USW Black
Post #73098 27th May 2011 4:46pm
galawaygreen
They must be crap mine are only a few months old
Post #73100 27th May 2011 4:52pm
WelshGas
They vary. Mine are 15mths old and pristine.
Post #73134 27th May 2011 9:38pm
Grockle
A lot of the issues are down to quality,we never had problems with mirror arms,headlamp bezels on earlier Def's the folding steps are a joke they start rusting within weeks, we are on our second pair of mirror arms,third set of H/L bezels and all the steps replaced. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #73170 28th May 2011 8:27am
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Same for me - mine were just changed under warranty.
Post #73242 28th May 2011 8:56pm
Alive Tuning
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Havana
If out of warranty, these are very cheap to buy anyway. A new mirror and arm assembly can be as cheap as £15 per side.
Post #73259 28th May 2011 10:49pm
Zagato
Roughly the same for a rim rusty headlight, and window catches, after market bumpers, rear folding steps, mudflap brackets etc that can also rust are peanuts so can always buy new if out of warranty and paint or treat it before you put it on Thumbs Up
Post #73284 29th May 2011 8:06am
FG
Sweden 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Got my light bezels and mirror arms replaced under warranty two weeks ago.
/FG
Post #73397 30th May 2011 7:12am
K9F
/FG
You can't make a silk purse out of a sow's ear and Land Rover has tried just that with the quality on certain items, as they are cr4p. Headlight bezels, sidesteps, front bumper, window hinge blocks, mud flap brackets, OEM A-bar brackets and wing mirror arms to name but a few. In my experience swapping out under warranty is just a 'sticking plaster fix' and the problem will undoubtedly reoccur sooner or later. I have either purchased quality after-market items or had the offending items removed and either chemically cleaned or blasted and a decent powder coating carried out for reasonable cost. (For example only £20 for a steering guard and A-bar brackets). Attention to detail is in my opinion what the Land Rover Quality Department lacks (if indeed there is such a department) and an eagle-eyed owner is much better placed to achieve the required standard of finish expected. For me I feel I am finally getting there after three years of ownership ironing out the minor issues myself. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #73427 30th May 2011 10:02am
Happyoldgit
But that's hardly the point is it Rolling Eyes The original parts should be fit for purpose in the first place Neutral Steve.
http://forums.lr4x4.com
Post #73436 30th May 2011 11:09am
K9F
I understand your frustration and your principle but unfortunately unless Land Rover are prepared to invest more time and money producing the quality customers deserve or listening to feedback you end up swapping things out under warranty until it expires, then eventually having to do something about it yourself!
I personally do not have the patience, time or inclination to continually go back and forth to my dealers to have the same things continually exchanged due to inferior finish/quality when it can often be reolved in a single hit for minimum cost! One of the characteristics of owning a Defender I suppose. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #73446 30th May 2011 12:42pm
