Home > For Sale & Wanted > [For Sale] Bits for sale
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Hi due to having had 4 operations on my shoulder in the last month I will not be owning a Land Rover for quite a while so Tash has cleared some bits from my workshop please let me know if you’re interested in anything Paul 07766 325028 or via here .
6 litres of Fuchs Titan hyp 90 GL5 80w-90 £18
Morris liquimatic D11 gearbox oil 5 litres £12
NX100L CCA 780 amps , ah (20h) 105 amps 12v (16”L x 7”W x 9” H inc terminal posts)new & unused £50
2x fuel filters rtc 6079 and genuine 90517711 £4
Brake hose rtc 3386G £7
8 x Thermostat gaskets for a 200tdi £1
Series 2 2.25 petrol AC Delco original fuel pump needs a new seal kit £15
brand new Hardi 12 v fuel pump pt/no 13312 for vehicles up to 60 hp £30
A pair of HTC seat covers 2 bases 2 backs and 2 headrests £10
Brand new Oblong reverse light and conduit to fit £10
brand new unopened Sealey 7.5 mtr inspection lamp £17
Series 2 rear prop shaft for a 109 with Salisbury diff brand new uj’s both ends but has slight wear in the splines £45
Yale HSA32000 key fob operated alarm system Kit 1, torn box window/door contact magnet missing £20
Wooden box with Lushington offset boring head & Attachments £? Offers please
Dynamat 3 x 4 square foot sheets of extreme dynamat £15 now SOLD Thumbs Up
2 x wolf wheels need a refurb £30
11 x 3 metre lengths of water hose £20
Many thanks Paul Tash n Barney
Post #731539 27th Sep 2018 5:59pm
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
Hiya, I'd like the alarm please subject only to knowing a bit more about the contents, can you Pm more pictures please? We have the same alarm system and it would help extend it further. V8 90...WIP
Post #731553 27th Sep 2018 7:18pm
Barneyboy
Hi I will ask Tash to grab it out for me in the morning as she is babysitting for a friend this evening 👍 cheers Paul
Post #731559 27th Sep 2018 7:50pm
Bluest
The item in the wooden box is an arbor for a milling machine possibly with a boring head. It's not the right taper for my mill, otherwise I'd have had it off you. it might fetch a few quid on eBay. See if you can get some better pictures if you want to know more. 2007 110 TDCi Station Wagon XS
Post #731584 27th Sep 2018 9:36pm
Barneyboy
Hi Bluest thanks for that I will get some more pictures of it many thanks Paul Tash n Barney
Post #731609 28th Sep 2018 7:02am
landy andy
Can I have the Dynamat. Please
Post #731610 28th Sep 2018 7:06am
Barneyboy
Hi Landy Andy it’s yours 👍 many thanks Paul Tash n Barney
Post #731611 28th Sep 2018 7:12am
It appears to be a small boring head with an NMTB 40 taper shank. If it was an R8 taper to fit my Bridgeport I would buy it, but sadly the NAT 40 taper makes it u/s to me.
New Chinesium boring heads of similar size on a Nat 40 taper start at around £90, which may give you an idea of value.
Post #731619 28th Sep 2018 9:02am
Barneyboy
Hi Bluest & Blackwolf the item is as you said a boring head size no1,Lushington precision offset,40 NAT F1, with 4 attachments Lushington cat no 1C , cat no 1B ,1B-30 & 1B-90 pat no 554820 I bought it years ago as I liked that it was in a nice original wooden box thanks for the heads up re value I will see if I get any interest on here,I will put that as offers I’m not going to be greedy I would rather it go to someone on here to be honest many thanks Paul Tash n Barney
Post #731624 28th Sep 2018 9:18am
Barneyboy
Hi I’ve had it out of the packaging and it’s all there bar the door/window magnet if you want it £20
Cheers Paul Tash n Barney
Post #731626 28th Sep 2018 9:25am
greenlandrover
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
2nd dibs on the Alarm if sale doesn't go ahead please Thumbs Up
Cheers,
Jason Discovery 4 - Aintree Green
Freelander 2 TD4 SE Automatic - Tonga Green
Defender XS - Tonga Green - Gone Now
Freelander 1 Td4 ES Manual - Epsom Green - Gone Now
Freelander 1 Td4 Kalahari SE - Epsom Green - Gone Now
Freelander 1 XEi - Epsom Green - Gone Now
www.greenlandrover.uk
Post #731642 28th Sep 2018 11:58am
Barneyboy
Hi Jason I will let you know if paulv8 doesn’t want it Thumbs Up many thanks Paul
Post #731659 28th Sep 2018 1:40pm
Paulv8
Hiya,
Just looked at the alarm contents and with the bit missing it wont work for me as that was the one bit that I definitely needed! So I will pass this time please. V8 90...WIP
Post #731660 28th Sep 2018 1:46pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
which part of Oxford Barney ?, Interested in WOLF RIMS Putting Dreams on Drives at JLR Solihull..
Post #734397 12th Oct 2018 6:29pm
Barneyboy
Hi adafiish we are 1 mile from junction 6 of the M40 Thumbs Up Paul n Tash
Post #734502 13th Oct 2018 12:28pm
