Home > Maintenance & Modifications > Oil leak and play on front diff
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Big leak and play in the front diff input shaft (pinion shaft?) Can it be tightened or is it better to just get the full diff out of something else and fit That? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #731208 25th Sep 2018 7:39pm
LR90XS2011
I believe the pinion bearings are set up with shims , hence play means the bearings are probably kaput so a rebuild or replacement is on the cards DEFENDER 90 TDCI XS,
Post #731216 25th Sep 2018 8:07pm
roel
You can check if the inputshaft nut is still tight. If so it probably would be better to take the diff oout and check the whole diff. Play etc.
If the nut is loose tighten it and if the play is gone you just need to change the oil seal. Roel
2003 90 Td5 (2009-now)
Post #731218 25th Sep 2018 8:08pm
IIRC if the bearings are shot the diff has to come out for access to the bearing.
There shouldn't be excessive lateral movement, only way of telling is if the pinion bolt is loose, if it is the seal it may be damaged and leak if torqued up unless replaced.
Hopefully a more knowledgable member will be along shortly. No Guts, No Glory.
Post #731220 25th Sep 2018 8:16pm
gazman
Yeah it's lateral movement. Had a horrible feeling it would be a replacement 2014 - current ..... 2003 defender td5 90 (my car)
Post #731239 25th Sep 2018 8:39pm
I'd just get a new seal, replace it and tighten up or get it done.
Then see how it goes, if it still gets lose or leaks again, get it out.
I've had mine repaired on the rear multiple times, not particularly loose but leaking. The seal keeps going, the pinion has been changed as well and still does it around every 20k so far.
There never seems a plausible reason for it, unless it's due to prop angle on the rear on the Puma with there transfer box nose down to the front.
At least try the cheaper option first, if I was you. Thumbs Up No Guts, No Glory.
Post #731269 25th Sep 2018 11:34pm
^^^ Next time mike up the part of the flange the seal runs on at several points across its diameter. I have found quite a few which have been sigificantly out of round which will cause premature seal failure.
Post #731274 26th Sep 2018 6:00am
