Home > Maintenance & Modifications > Water proof connectors for spot lamps. |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 286 |
Try these from Polevolt - https://www.polevolt.co.uk/acatalog/Large-...tml#SID=55 NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
23rd Sep 2018 8:24am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4210 |
They look just the trick 2007 110 TDCi Station Wagon XS
23rd Sep 2018 10:02am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
They are Superseal connectors. Can get a proper crimping tool for eco and superseal connectors. Can be crimped with needle pliers etc with care. However if badly crimped or distorted then will not fit into the plastic housing properly.
Brendan |
23rd Sep 2018 11:45am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
I did all of my Econoseal connectors with needle nose pliers, mainly because haveca better feel of how tight they are and for precision. I’ve never had an issues with any at all.
For high current loads the smaller Anderson connectors and rubber boots are extremely good if fitted properly. The joint between the two plugs can be sealed using one wind of high quality electrical tape with a tear off tab. Then you can rapidly remove if needed. And use the Anderson dust caps as a temporary protection. But I do like to go overkill on such things for maximum voltage and with low losses. Those connectors above should be fine though for the intended application. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 Last edited by custom90 on 23rd Sep 2018 7:56pm. Edited 1 time in total |
23rd Sep 2018 12:23pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 623 |
Do you really need connectors there? How often do you plan to disconnect the connector? These connectors are fine, but for remove "once in five years", standard (spade, faston or how it is called) connector and some heatshrink tubing with glue inside is also good. Cheap and easy to mount, and very small. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
23rd Sep 2018 6:10pm |
Connectors definitely needed. I change my mind on front lighting setup about twice a day. I’ve had the grille off more times than I can count. Current spots are only interim items so will get replaced at some point. 2007 110 TDCi Station Wagon XS
23rd Sep 2018 7:48pm |
