Home > Maintenance & Modifications > Paddock wingtop chequer plate - bolt holes
c_eilersen
Denmark 2006 Defender 90 Td5 ST Tonga Green
Hi,
I am considering to change the wingtop chequer plate on my defender 90 from the original straight aluminium to some new black 3mm ones from paddock spares.
I do not want to drill anymore holes in my wings - Can I assume that the bolt holes on paddock version will line up with the holes used with the original chequer plate on my car?
The car is a 2006 Td5.
best regards,
christian
Post #730566 22nd Sep 2018 9:23pm
I don't think you can assume that, unfortunately. There are lots of different makes and there's no guarantee that they all use exactly the same pattern Darren
Post #730568 22nd Sep 2018 9:36pm
zsd-puma
Take the old chequer plate off and have someone powder coat it black for you. Wink
Post #730589 23rd Sep 2018 5:36am
L110CDL
^^^ that's what i did Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #731009 24th Sep 2018 9:47pm
c_eilersen
You are probably right - that might be the best solution...
thanks Smile
Post #731242 25th Sep 2018 8:44pm
