![]() | Home > My Defender > Weekend Job: Lowering and Softening my Defender Suspension |
mrd - i had the konis firsty. The improvement was good, but it was still jolty at the back, especially unladen. The spings and konis together made it spot on
Pics of the Alive uprated ARB. Dug it out of storage at the weekend.
It could do with a bit of a spruce-up before fitting (if you are as fussy as me!). Includes mountings, polybushes, and nuts/bolts. One of the nuts is missing for some reason but I assume the originals (the ones you take off) will fit ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Looks about 35mm-38mm diameter £100... First dibs to Oakseywick in honourable def2 fashion ![]() |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Kames - the fronts are "Defender Koni Shock Absorber Front TD5 8240-1181SPX" - from Defenderbits... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Thank you. James
Aha - Update - 1st dibs wend to Oaksey, but sold to James ...
Let me know how you get on James - courier booked ![]() |
