Home > Technical > a dash that is driving me crazy |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Lubricate the bonnet hinges. A common noise that you would bet was coming from the dash area. Try them first.
21st Sep 2018 10:16am |
rillas Member Since: 27 May 2012 Location: warilla nsw 2528 Posts: 16 |
thanks i will do in the morning
21st Sep 2018 10:18am |
Forgot to add, if that doesn't work check the bolts that hold the roof on especially the screws in the corners which have a habit of working loose.
21st Sep 2018 10:20am |
edo Member Since: 20 Aug 2018 Location: Devon Posts: 372 |
Click image to enlarge |
21st Sep 2018 10:35am |
Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
21st Sep 2018 11:41am |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 226 |
Anyone remember this one.
21st Sep 2018 12:19pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5108 |
Place a cat inside your dash, then a dog, then a duck etc. etc. E-I-E-I-O For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
21st Sep 2018 4:25pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 926 |
I remember that vw advert! Was only 8 in 1990!!
21st Sep 2018 4:32pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
I've got a pair! The sound cancelling is flipping amazing. So good, some pilots use the aviation version that has a mic! ... now.. imagine an intercom system in a defender |
21st Sep 2018 7:11pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10731 |
I have got a pair as well and they are .......... amazing 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
21st Sep 2018 9:27pm |
I suspect we're not helping much Darren
21st Sep 2018 10:11pm |
Check the wiper motor is secure on it's bracket (Access via the speaker hole)
Check the engine ECU is tight in it's bracket, the bottom of it is just some foam wrapped around it and jammed into a slot, the foam wears then develops into a knocking. |
21st Sep 2018 10:50pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 729 |
I would start with the basics and check all the dash fixings for tightness. The dash could be just loose and rubbing on the body.
22nd Sep 2018 7:31am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6602 |
I've got a similar problem ever since it went into the dealer last winter
I've released and tightened everything and it is still rubbing/squeaking in the middle. Massively irritating as it was genuinely squeak and rattle free before 1988 90 Td5 NAS soft top 2015 D90 XS SW |
22nd Sep 2018 8:53am |
