Home > Maintenance & Modifications > Should I weld half shafts to drive flange?
Co1
After a whopping 50k, the splines on my rear half shafts and drive flange are knackered. Paddock sell and integrated unit, so would it be daft if me just to weld them together to achieve the same result? The alternate is the genuine LR part at £200+ and given the short life of the original that seems pointless. Non OEM ones are more appropriately priced, so this would be the fallback.
Any thoughts?
Col
Post #729934 19th Sep 2018 5:26pm
This was discussed a couple of weeks ago and the consensus was that unless you're a very good welder, you won't get the penetration needed to make a decent job of it.
I've just fitted genuine one piece shafts to mine and they have made a real difference. I did manage to pick them up for a very good price, though. Darren
Post #729948 19th Sep 2018 6:31pm
Co1
Cheers, I have a good mate that is a coded tig welder, so comfortable getting the quality. I guess my other concern is that this is essentially the sacrificial part, so if I make it solid am I not going to make the diff end the sacrificial section?
Post #729952 19th Sep 2018 6:39pm
No. It's only sacrificial because it's not lubricated, which doesn't apply at the other end. Darren
Post #729954 19th Sep 2018 6:40pm
Co1
Makes sense, thanks.
Post #729959 19th Sep 2018 6:47pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
If you search backlash sorted you'll get to the thread mentioned above, complete with pictures.
Post #729966 19th Sep 2018 7:12pm
