Home > Off Topic > Driving Licenace Confusion - E Trailer |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 |
Nope. The +E entitlement cascades down, not up.
https://www.gov.uk/adding-higher-categorie...ng-licence |
17th Sep 2018 7:28pm |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 |
as above, there's another test you need to do that will give you C1 + E on the license 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
17th Sep 2018 7:36pm |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 490 |
Ok, Next question then...
Can I complete a CE licence or do I require to Complete a C first? Thanks Andy Working towards Carry on camping! |
17th Sep 2018 7:46pm |
that's something the local training center will be able to confirm, but I believe you do 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
17th Sep 2018 7:48pm |
Jimmy B Member Since: 11 Nov 2017 Location: Cumbria Posts: 51 |
you will have to do C1 first then C1+E . It wouldn't cost much more to do C first which lets you drive any rigid wagon then C1+E
17th Sep 2018 8:00pm |
Thanks Guys,
I will call the Training Centre tomorrow where I completed my BE and have a chat.. Thanks Andy Working towards Carry on camping! |
17th Sep 2018 9:06pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4789 |
Just do your HGV test and be done with it
It would enable you to drive/tow any combination apart from minibus I believe 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
17th Sep 2018 9:36pm |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 |
As above, may as well do your C&E if you can, covers you for everything then. 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
18th Sep 2018 4:00pm |
Wangers Member Since: 19 Jan 2013 Location: West London Posts: 265 |
B - Vehicles more than 2 wheels, upto 3.5t, trailer upto 750Kg
BE - '' trailers over 750Kg upto Train Weight of 7t C1 - Vehicles 3.5 - 7.5t, trailer upto 750Kg C1E - '' trailers over 750Kg upto Train Weight of 12t C - Vehicles over 7.5t, trailer upto 750Kg CE - '' trailers over 750Kg (though a 102 restriction code limits to wagon and drag only, NOT artics - no 102, no restrictions) So B over 750 = BE BE over 7t = C1E C1E over 12t = CE CE though does not always mean you can BEm depending when you passed what test. And date of passing what test (or grandfather rights) make a massive difference. TY&GN 10 years in a WOLF, WIMIK and Snatch and this is all I have to show! |
18th Sep 2018 8:24pm |
For clairity, as this point gets confused. If you do B&E, and then, say, Cat C, you can only tow 750KG behind a cat C vehicle, not 3500KG which many people assume. The "B" entitlement does not carry over to the next class up. To tow anything over 750KG (eg a 3500KG trailer) behind a cat C vehicle you would need C&E. 2011 110 USW
19th Sep 2018 2:30pm |
Wangers when would doing C+E not also give you B+E and C1+E?
19th Sep 2018 8:39pm |
