Home > Maintenance & Modifications > Damper/spring advice for a 90
Page 2 of 2 <12
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I've fitted defender 110 front springs front and rear to my 90 with the rubber spring isolators. I believe they're fitted to the rear of disco's too. It has made a massive difference to the ride, can actually feel the axles moving rather than smashing over bumps. The car has standard anti roll bars and roll may have been compromised a tiny bit but not as bad as I expected.
I will be fitting fox shocks next year as I feel he former damping with soft springs will make it exactly how I want it.
Post #729612 17th Sep 2018 7:37pm
Mike_E
United Kingdom 2015 Defender 90 Puma 2.2 HT Aintree Green
Landyman,
Does the car still sit flat with the 110 fronts on the rear?
Mike
Post #734747 14th Oct 2018 9:14pm
LandymanStefan
I put a spring isolator top and bottom of the spring on the rears and only one isolator on the fronts and it's seems level to me
Post #734760 15th Oct 2018 5:10am
Mike_E
Spot on. Thanks
Post #734761 15th Oct 2018 5:13am
Page 2 of 2 <12
