Home > Maintenance & Modifications > New type hand brake Assembley to 1993 200 tdi 110
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
Hi any one fitted newer type hand brake (cable straight to the back plate) to a 1993 200 tdi 110, after replacing shoes and cable its at full adjustment on the cable and the shoes are set / adjusted right , it seems very cleaves pin and yoke is worn out , was thinking of replace the whole lot. 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #729137 15th Sep 2018 8:22pm
jst
Have you adjusted it on back of the mechanism through seat box as well as drum end? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #729144 15th Sep 2018 9:12pm
natyeo
Yes and two different makes of cable used , no major wear on the drum either 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #729148 15th Sep 2018 9:21pm
jst
how many miles on the drum setup, which presumably came complete off a newer vehicle 2nd hand? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #729647 17th Sep 2018 8:43pm
natyeo
After 2nd new cable and yet another set of shoes, I put old cable next to the new ones , bearmach or britpart , were slightly different length , lots of WD40 and gentle heat ,freed it off and put one old back on , worked fine with more adjustment left too. In this world it seems to be such a wast that so many replacement parts are utter crap what a wast of raw materials! 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #760469 23rd Feb 2019 9:33pm
