![]() | Home > Puma (Tdci) > Rattle/buzz at 1500/1550 revs |
What engine?
To be honest though, it could be anything and will be difficult to track down by just pushing and prodding. Can you get somebody to rev the engine whilst you stand in front with the bonnet open? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 593 ![]() ![]() |
2.2 Puma
I’ve done that but it only does it under load. I’m looking at setting the go pro up pointing at various parts and driving with the bonnet off to see I’ve ican get closer to the source The post was more to see if anybody else had a similar rattle |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1676 ![]() ![]() ![]() |
Turbo heat shield?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
My guess is this too. ^^^^
Also check the red lifting eye on the back of the engine that it isn't loose. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 187 ![]() |
Mine does it too.. does yours stop if you take a sharp yank left or right at the steering wheel, while accelerating? No rear engine lifting eye on mine, so can’t be that. I was thinking it could be injection timing. Oddly though, when the engine is cold it still does it, but rises in pitch at the same time. Very odd. |
I’ve checked bolts holding turbo heat shield and have tried bending it up and driving bending it down and driving bending it left bending it right.
This is off a transit but my actuator rod moves like this. Not quite as bad but a potential candidate for the rattle. |
Dobby mine doesn’t change with steering I don’t think but I’ll give it a go today.
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
& me. |
Next move is to remove heat shield and try that.
I could be imagining it, but I’m sure the noise went away as I was accelerating up a hill the other day, and had to ‘avoid’ something. |
I’ll also check the power steering pump then
