Home > Puma (Tdci) > Dpf warning lamps
Vitesse
Dpf warning lamps
Hi. Does anyone know exactly where in the instrument cluster that the DPF lights show up ?
My manual describes them but doesn’t point out where they actually light up?
Thanks. Thumbs Up 2015 90 XS Santorini Black
Post #728263 10th Sep 2018 11:59am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
In the square below the temp / fuel gauge.
Post #728265 10th Sep 2018 12:13pm
Vitesse
Thank you. That confirms perfectly.. I am lookign at fitting Ultraguage in that position so will be coming up with a plan to sort the DPF lights out somehow..??
Post #728283 10th Sep 2018 2:09pm
Roy5695
I relocated my DPF lights to inside the Rev gauge. Using some thin cable and copper track board. De-solder warning lamps from the clocks. The soldier in wires where the LEDs were then connecting them to the board and soldering the LEDs onthe right place.
Then all you’ve got to do is make sure you place the DPF warning light symbols (of which you’ve cut off the clocks to fit the ultragauge in place) over your LEDs you’ve relocated. Hope this makes sense Rolling with laughter
And if you do it right you’ll never know it wasn’t supposed to be there. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #728442 10th Sep 2018 10:57pm
Vitesse
Hi ..thank you. Thats excellent. Good to know its actually a practical possibiltiy. I will dust off the soldering iron and anti static mat forthwith! I will be doing some of the core cuttting out using parts from a Disco 3 dash but all noted re the DPF lables etc. Thumbs Up 2015 90 XS Santorini Black
Post #728466 11th Sep 2018 8:21am
