Home > Expedition & Overland > Roof Rack Failures.....?
Page 2 of 2 <12
Bluest
A bit of roof rack based viewing to add to the mix of views.
 2007 110 TDCi Station Wagon XS
Post #727877 8th Sep 2018 6:53am
leeds
He certainly does not understand the meaning of the word modular!
Modular to him means continuous load ring tracks. 5 load rings to be fitted per track recommended?
Also does not what a snake sling is and its uses.
Good he mentions low profile.
However no real mention of load on rack and effect of COG. Fuel cans on rack? Much better to fit long range tanks if you actually need the extra fuel. Water either build in tanks now down or use bladders.
Consider carefully what you intend using the racks for and where you intend going. Do you actually need a rack or would GOOD roof bars suffice?
Brendan
Post #727897 8th Sep 2018 9:22am
Markez79
Many thanks for the video. I had seen that already and was the first time I had heard of the Eezi Awn K9 which looks good, especially as it has 8 legs each side which should help with my concerns.....
He wasn’t very complimentary about Frontrunner.
Thanks
Mark
Post #728219 10th Sep 2018 5:31am
Page 2 of 2 <12
