![]() | Home > Puma (Tdci) > has anybody tried to move the aircon vents on the puma |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2119 ![]() ![]() ![]() |
There are vents at the end of your dash for demising that work quite well in my 110 ... if you feel that it may be needed then look at re-directing these to push the air forward and block the outlet from the central vents to see if this works ...
I prefer to have the centre vents as they push the air up and over into the back of the vehicle circulating the air, but thats my presence only ! ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Anything is possible. But I think doing this and making it look professional is going to be a massive task. The ducts through to the side window de-misters are quite small because there isn't much space behind there to put larger ones in.
Adding acoustic/thermal insulation (4mm foil covered foam) into the vehicle helps at lot, as does fitting the later type lower door seals if you don't have them already. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
as noted above trying to do a decent job of it would not be easy.
I'd consider all other options first - if heat really is a problem look at installing one of these perhaps; https://uk.images.search.yahoo.com/search/...tion=click or a fridge in the back with the lid left open. |
