Home > Series Land Rovers > Fitting new exhaust... Right pain |
I'd be sending that back Darren
6th Sep 2018 10:13am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3786 |
^ I can get it much better than the picture shows, thats with the bolt lose.
If I hold it straighter and tighten it then It's much better but still not flush. Should it be flush? ie touching each other tight |
6th Sep 2018 11:16am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17539 |
Yes, it should be flush and should butt straight on to the manifold.
It's either completely the wrong shape, or else you are running it under the gearbox crossmember instead of above it. |
6th Sep 2018 11:37am |
Does this look correct how its routed?
I'm sure I copied the old one but maybe not? Click image to enlarge I will try an enlist a friend to help me twist it while I tighten it up |
7th Sep 2018 8:56am |
That does not look right to me, it is much too near the ground, it should not be that low under the crossmember. If I remember correctly it should pass under the crossmember much nearer to the chassis, so that the exhaust pipe is not really any lower than the lower face of the crossmember.
7th Sep 2018 9:55am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
It doesn't look right to re either, I'd try it the other way around possibly.
As Blackwolf mentioned, it looks to be sitting too low to me as well. KEEP CALM AND Drill ON đŹđ§đ´ó §ó ˘ó Ľó Žó §ó żđ´ó §ó ˘ó ˇó Źó łó żđ´ó §ó ˘ó łó Łó ´ó żđŽđŞđşđ¸â˝ď¸đ˘ď¸âď¸đ§°đŞ |
7th Sep 2018 10:24am |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3384 |
That's way too far across under the cross member, heres a pic I've just taken of mine...
Click image to enlarge |
7th Sep 2018 10:53am |
And the next section along.....
7th Sep 2018 11:03am |
Thanks people
I will have another look over the weekend. Any more pictures of how it routes the better as I've printed them out to look at mine. |
7th Sep 2018 2:37pm |
All I had it routed wrong !!! đ
Next issue should his front connection be but up to each other as I can get it right (the picture is lose) but it's not bang up tight there is still a gap? Click image to enlarge Thanks |
7th Sep 2018 4:21pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 769 |
That's how it should be.... A gap between the flange and the manifold đđť..... Don't tighten it up until you have the whole system on the vehicle.
7th Sep 2018 4:34pm |
Is the Gap normal? as it will not go tight and flush even now. Its still as above just tighter and a bit closer.
The big 'washer' on the exhaust side does not clamp up to the bottom of the manifold flush? I don't want to start doing the rest if this isn't right? |
7th Sep 2018 6:57pm |
Yes, the "gap" is correct, the "big washer" you describe is clamping the fitting on the end of the downpipe into the manifold đđť
8th Sep 2018 6:28am |
Fitted
Thanks for help, Yes I had it routed incorrectly so the first picture now is much tighter even than in that picture and more sealant for good measure. Click image to enlarge Click image to enlarge Click image to enlarge |
13th Sep 2018 10:48am |
