Home > Td5 > Spring rates
lightning
Spring rates
Last week l drove a Defender 110 2.4 XS TDCi and the ride quality was definitely better than my TD5.
For instance the TDCi floated over a rough cobbled track where my 110 TD5 CSW would have been harder work. I already have adjustable shocks (and it is better than standard) but the TDCi was still better.
I can only assume it’s due to different spring rates. So if l fit standard TDCi SW springs to my TD5 is it going to ride like a TDCi?
Has anybody tried it, or is it down to me to try it and report back!
Post #727605 6th Sep 2018 6:19pm
MartinK
Check my thread here http://www.defender2.net/forum/topic13312.html
It has the spring rates on Page 2.
and here http://www.defender2.net/forum/topic49065.html?highlight=isolator
I've done a lot to get "Disco2" quality road manners
Changing the shocks to Koni really helped too - mine has a really comfy ride now, especially with 35psi in the back tyres Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #727714 7th Sep 2018 8:42am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Changing to progressive springs like the Puma had helps a lot. Isolating the springs from the frame helps much more to stop a harsh ride.
Use Disco II spring isolators on the top of the front prings and OEM 110 spacers for the rear. If you want really cushy ride install standard isolators to the bottom of the front springs as well. The rears should have the stock isolators already on them (ANR3060)
Good luck
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #727781 7th Sep 2018 4:10pm
ibexman
It’s all in your head the tdci is a quieter car anyway Whistle
Post #727785 7th Sep 2018 5:11pm
Do you have any more details on those OME 110 spring isolators, please? My Google powers are failing me. Darren
Post #727787 7th Sep 2018 5:18pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Check out here gives you part number and I'm sure you can order from someone closer Thumbs Up
https://expeditionexchange.com/shop?olsPage=t%2Fold-man-emu
Post #727805 7th Sep 2018 6:59pm
Great, thanks. Darren
Post #727830 7th Sep 2018 8:45pm
lightning
That’s really useful thanks for the replies. I will do as suggested, Puma springs with isolators.
Yes the Puma was also quieter than my TD5!
Post #727902 8th Sep 2018 10:48am
4RF RDS
Those OME isolators are actually for Toyota Tundra. You can alao find rubber ones which can do the same thing. Glad to help out. I got mine here. (Link saved in £ for you).
Good luck.
http://www.lowrangeoffroad.com/catalogsearch/result/?q=OME80PR10 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #727931 8th Sep 2018 3:46pm
Thanks. Found them at Devon 4x4, but they're £25 for two inc. postage Shocked Darren
Post #727984 8th Sep 2018 9:26pm
