![]() | Home > Puma (Tdci) > Rear fog light control circuit |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Under the drivers seat there is a Fog lamp control unit. It usually says so on the label.
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 ![]() ![]() ![]() |
http://www.defender2.net/forum/post723463.html#723463 Paul.
1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 389 ![]() ![]() ![]() |
Thanks all. I managed to source one of these ecu relays on eBay. Using it for a project to control usb power in the 90 using a modified LR switch
What have you got planned, Vitesse? If you use the right switch, it shouldn't be necessary to modify anything to operate one of these relays. Darren
Hi. Going to use a modified momentary switch with a sort of custom front cover and graphic. The idea is that the usb can be switched on by the passenger but when the engine is stopped then it all powers down. I don’t want the usb quiescent current running all the time So the ecu fog light relay is ideal for this task. It’s a bit of a project and possibly overkill. :c
Not overkill at all! I'm using exactly the same principal to control my rear work lights except that the power feed is interrupted via a changeover relay when the brake pedal is pressed, so I can't drive off and leave them on. The standard fog light switch is, of course, ideally suited to triggering the relay.
How do you plan to change the graphic on the switch? It's something I'm working on but my first attempt wasn't brilliant and I'm looking for alternative ideas. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Like your idea on the rear light. 👍 The graphics for the switch is work in progress. I am in touch with a company that does automotive switch etching. Hoping to get something that way. Have already got the blanks made from old switches but you can use the standard blank covers. Just need to drill a hole if an indicator is required and fit the prism. In the mean time I have modified a discovery 2 fuel filler switch cover. The picture looks a bit like an iPod with a wire coming off it. That will do for now
I'd be really interested to know how you get on with the etching as I've got a whole load of switches I'd like done. Darren
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 ![]() ![]() ![]() |
The etching is relatively simple, just need a mate with a laser/CO2 engraver.
I've had some done, the trick was to do some test runs on an old switch cover to get the alignment & depth spot-on. http://www.defender2.net/forum/topic42402.html http://www.defender2.net/forum/topic53098.html Can post some templates I've already made if needed? Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
Well that's the trick, isn't it ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
