![]() | Home > Puma (Tdci) > Engine lift bracket |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
it's supposed to be removed on the production line once they'd fitted the engine/gearbox assembly or by the dealer during PDI.
There was a TSB about it, where during routine servicing dealers were supposed to check to see if one was still there and bin it if it was. It risked rubbing through a couple of hoses I think. |
Blimey, I'm surprised that there are any of those still left in place. Just remove the remaining bit and throw the whole lot away. Darren
looking more closely at the pic, I expect someone (probably in a dealership) tried to remove it but the bottom bolt was stuck so they just took the top one out and then rotated it out of the way, at which point the vibration has gradually fatigued the metal.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
Mine's still fitted and causes no problems at all (2007 Defender, 226k miles).
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
They must have been good fellows with mine and removed it πππ
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
Mine was left attached, and wore a hole in the cabin heater pipe.. Take it off, and bin it.. ... ,-------,
.. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
You'll regret taking it off when you need to lift the engine out.
A better bet is to make sure that it is bolted on properly and that no pipes or harnesses are chafing on it. |
At Β£50 to replace the per then at too days price
can always take it off and lob it in with your tools/back of garage. It's not as if putting it back on would massively extend engine removal time. Or that you'd need it at the roadside.
