![]() | Home > Puma (Tdci) > Puma stereo in another car |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
I have sold my original stereo to a friend with Jeep.
Everything works fine, but the security code - he needs to type it in every time he starts the engine. Is there a non-ISO signal fed via ISO connector by Puma to prevent it? Or something is definitely missing from the connector on the Jeep side? Cheers! Janusz www.yahodeville.com |
Landie Boy Member Since: 14 Jan 2011 Location: Essex Posts: 431 ![]() ![]() ![]() |
When he enters the securit code, does the device load the preset channels from before?
Jack |
Look for the main power. there are two +12V cables, one on battery (so the radio do not ask the coda all time) and the 2nd one +12V switched. The LR radio have ISO connector (socket A and B on the attached pic.) ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Thanks, will take a look (should look for these diagrams first
![]() Cheers! Janusz www.yahodeville.com |
It's probably just the LR stereo rejecting the Jeep
![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
http://en.wikipedia.org/wiki/Transplant_rejection
It may be destroyed! ![]() www.yahodeville.com |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
I had exactly the same behavior. As Dgardel sys, is about the two +12V cables. Make sure that they are not swapped (pin 4 on pin 7). In this case the radio will work fine but will lose memory when the power is cut. |
Swapping 4 with 7 fixed the problem and earned me a beer
![]() I can share it with you guys, if you are around north-east Poland. ![]() www.yahodeville.com |
