Home > Off Topic > Power Supply to Garden Workshop |
PME Protective multiple earthing
31st Aug 2018 7:15am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
Agree
That sounds to me more like a 415V three-phase supply. Perhaps you are getting your mains from one (or more) phases. |
31st Aug 2018 7:19am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
/\ as you say either it's not HV or it's 400v (415v is old school ) or there is a transformer somewhere - and it's usually fairly obvious.
31st Aug 2018 7:32am |
[quote="apt100"]
Would I not be right in thinking without a neutral supply the RCD will trip ie there'll be a potential difference between the phase and neautral? If not then a guess there's no need to worry because you'll be no worse off than 95% of people in this country and guess there's also the questions of whether your looking to carryout an install that meets current regs or looking to overcome every possible eventuality? not trying to have a dig here but more concerned that what little knowledge I have / had as either gone or become rusty |
31st Aug 2018 7:45am |
RCD
Under normal circumstances, the current flowing in the two wires is equal. When an earth leakage occurs due to a fault in the circuit or an accident with the equipment, an imbalance occurs and this is detected by the RCD, which automatically cuts off the power before injury or damage can result. |
31st Aug 2018 9:32am |
/\ exactly.
an inbalance (fault) will cause the RCD to trip. an overload which is generally a different type of 'fault' will not trip an RCD but should take out a fuse or MCB. 30mA RCD for protection to life 100mA RCD for protection of property (typically) |
31st Aug 2018 9:36am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Going OT and just to satisfy my curiosity what is correct/legal/conforms to part 17/18 way of earthing/providing electrical safety at caravan parks? Just curious as we sometimes plug into outdoor supplies on caravan sites. How are caravans protected electrically? Brendan |
31st Aug 2018 10:13am |
I believe you'll find it's via an RCD.
31st Aug 2018 10:16am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2642 |
As far as power distribution networks go, usually (but not always) if you have wires mounted vertically above one another than it's a low-voltage circuit (i.e. 230/415v). The lines with the wires mounted in a line horizontally will be HV so most likely be 11kv minimum, potentially 32kv. If you trace your vertically-hung wires back you will get to a transformer on the HV line somewhere. The three lines can also sometimes be combined into one three-core insulated wire.
When I put the power supply in to my workshop I dug the trench, laid the conduit, pulled the cable (10mm^2 SWA) through and mounted the workshop consumer unit. Then the sparky hooked it up to both consumer units for a few hundred quid. I did all the subsequent circuit wiring inside the workshop. That's for a 40A supply from the house. The requirement to use a Part P certified electrician doesn't exist in Scotland however, everything just has to be done to the correct standard. |
31st Aug 2018 11:03am |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
https://www.tlc-direct.co.uk/Book/7.14.1.htm has useful information for this and other types of installation. |
31st Aug 2018 11:45am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20347 |
Interesting. I'm no expert on it so many of you probably know a lot more than I do.
We have quite a nest of overhead lines here! There are some very large NG metal pylons out in Wilts and South Glos. Some of which are networks across the Severn Bridge and Avonmouth etc. Such large pylons that the have a large V formation of insulators on them and you can hear them buzzing especially in damp weather in the winter with a high load. Corona Discharge basically. Rather un-nerving if your close especially knowing they are 250kv upward minimum. NG have a map I think on their pages somewhere. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
31st Aug 2018 2:49pm |
Interesting photo Corona Discharge 500kV:
Click image to enlarge Further info: https://en.m.wikipedia.org/wiki/Corona_discharge $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
31st Aug 2018 3:13pm |
The biggest transmission lines (line the one across the Severn at Aust, by the bridge) are 400kv. With the rest of the transmission network being made up of 275kv and 132kv. Distribution then generally takes over for lines at 33kv, 11kv and low voltage (230/415v).
The bigger the line, the more important it is. There are two lines feeding from Scotland into England, and the capacity of these lines being exceeded is often the reason why windfarms are required (and paid) to turn off up here. Most of the grid demand is in England after all. I heard a while back that a new third link via subsea cable in the Irish sea was being considered. Try phoning them up and asking if they can shut down the 400kv western England/Scotland link so you can fell some trees alongside it - worth a laugh for their response |
31st Aug 2018 3:17pm |
31st Aug 2018 3:28pm |
