![]() | Home > Tdi > What Fuel Tank do I need? 200tdi Richard chassis, TD5 mounts |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
If it has the standard TD5 fuel tank mountings then the standard TD5 plastic tank will fit. Though you may have to purchase a fuel tank cradle and various other brackets. If you are not in any rush most Land Rover breakers have TD5 tanks, in fact, the last time I visited a breaker they had about thirty of them piled high.
You may find this a help. https://forums.lr4x4.com/topic/71138-td5-fuel-tank-in-200tdi/ ![]() Click image to enlarge For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
Thanks Gilarion,
looking on Paddocks, all Defender 90 tanks are the same as front mounted ones i.e. same as i already have Every other one is a 110 or 130 tank.... I mean why is that ? You know the main reason is the availability of new parts, anywhere in the world if I needed it. Having a stack of 2nd hand ones in a UK scrapyard isn't my idea of future proofed. Also don't want to end up with a bespoke pipework situation for a tank that will be impossible to source in the distant future. Maybe i'm too pedantic.... |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2698 ![]() ![]() |
Unless you puncture it you are unlikely to ever need to replace the tank. The plastic one don’t rust like then earlier metal ones do. No need to buy new either, for the same reason. Good condition second hand will do fine.
A Tdci tank is as far as I am aware the same as a Td5 one in terms of fitment. And having a Tdi you’ll actually need to use the Tdci sender & fuel pickup unit as the Td5 one has a pump in which you won’t need. You will end up with a ‘custom’ arrangement to some degree but it’s just two lengths of 5/16” fuel hose and your changeover gubbins so hardly difficult. Or you could fit a transfer pump. |
Sorry forgot to post the part number for the fuel tank which is available from all the usual stockists
Fuel Tank 90 TD5 WHK100040 Pricey though... For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Would i be able to jerry rig the td5 pump/sender/pickup unit to pump into the primary tank i wonder ? From what i can gather the td5 has a high pressure and low pressure loop, could these be bypassed into each other and put on a switch ? |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 490 ![]() ![]() ![]() |
Hi, I have a good used 90 Td5 Tank and Craddle
![]() Click image to enlarge Pm if intreasted Thanks Andy Working towards Carry on camping! |
