Home > Technical > Headlights not working after removing drl’s - fixed
Likeomg
Removed my drl bumper and lost my headlights...
I’ve also removed my lazer rs8 as the soft a bar isn’t compatible with the bowler bumper
There was a feed from the side lights (which still work) for the drl bumper which was used to dim the drl’s When lights came on...
Can’t see this being a issue ? I’m guessing it has more to do with the removal of the rs8?
Anybody have a idea ?
Post #725826 28th Aug 2018 3:50pm
RS8's were probably taking a trigger tap from the main beam feed, you may accidentally have had a short or there maybe one somewhere.
That is presuming the fuse has blown, has it blown?
Do you have an additional loom such as Land Reiziger or Boomslang? If so, check fuses there also.
If any fuses have blown, that'll be an instant indication of a short within that circuit it protects.
If no fuses are gone, it could be the headlight switch contacts that old chestnut but if you have LED lights this is less possible but never the less a possibity. KEEP CALM AND Drill ON
Post #725830 28th Aug 2018 4:11pm
Likeomg
I guess first test is plug the rs8 back in and see...
Jw speaker evo 2 & it has an additional loom...
Back in 30 so will start fault finding
Post #725833 28th Aug 2018 4:17pm
Likeomg
Nothing changed with rs8 plugged back in...
High beam indication is on when i go to main beam... ?
Removed the landziigger (forget the spelling Shocked loom and it’s working....) hmm
Post #725850 28th Aug 2018 4:46pm
So you are getting sidelight and main beam, but no dipped?
Or just sidelight, main beam indicator on dash but no headlight main beam nor dipped either?
Check the fuses on the LR and the additional loom, and if they check out fit the LR H4 connectors without the additional loom and see if that woks.
If it does the additional loom is the issue.
It seems like you may have disconnected a trigger feed for your additional loom hence some lighting working but not the others.
Sidelights are always switched via the LR loom, the dipped and main beam via their own dedicated relays if an additional loom is fitted.
So if you are misssing say dipped or main separately the trigger feed is not there.
If both don't work then it could be the LR loom.
If no fuses are blown at all, then it's likely the trigger feed is not present after removing the RS8's. KEEP CALM AND Drill ON
Post #725853 28th Aug 2018 5:01pm
If you haven't already done so try removing the dim dip plug under the OSF wing too, it can always be plugged back in anyway.
I remember I had issues at one time with this, but I can't remember how I solved it. KEEP CALM AND Drill ON
Post #725855 28th Aug 2018 5:06pm
Likeomg
Just like Steve said...
I disconnected the perm live as I didn’t think it was needed...
Thought it just turned the drl’s on... typical my soldering iron is down on the farm
Quick fix, thanks for the fault finding tips
Edit - removed dim dip years ago, it was giving problems with the original jw speakers I had installed
Post #725864 28th Aug 2018 6:01pm
Excellent. Thumbs Up
I had issues with the Dim Dip too with LED headlights so disconnected mine to a few years ago. KEEP CALM AND Drill ON
Post #725866 28th Aug 2018 6:06pm
