Home > Puma (Tdci) > New rattle |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4615 |
Check the heat shield on the turbo.Check all of the bolts that you can find. 1982 88" 2.25 diesel
14th Feb 2009 6:51pm |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 |
While on the subject of loose nuts and bolts, I'm getting a little concerned at how many have come loose, or have not been tightened up correctly in the first place.
Heat shield as already mentiond. Earth strap to chassis, by front off-side wheel. All three door stay springy things (on my 90). PAS fluid reservoir. A/C drier. Side step bracket. Not a nut or bolt, but the fuel breather has come adrift. Although none of the above were strictly "safety critical", it makes me wonder what else may come loose that is safety critical!!! Bosun. |
16th Feb 2009 8:44am |
