Home > Off Topic > DIY aids
spudfan
Ireland
DIY aids
For mixing paint I use an old paint bucket with a hole in the lid. I put the mixing paddle through the hole, close the lid and attach it to the drill. I can then mix the paint without any splashes.
I needed some countersinks for a project I was working on (a picnic bench). I bought some but they came in a blister pack which was no good for storage. I used an off cut of wood to make a storage rack for them. I used each item to make a hole for itself. I also made a storage hole for the Allen key that is used to loosen and tighten the grub screw on the countersinks. This fits in the drill case.
 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #724862 22nd Aug 2018 4:57pm
X4SKP
Hello spudfan
My best DIY aid...
http://www.defender2.net/forum/search.php
Followed by...
 SKIP
Post #724868 22nd Aug 2018 5:45pm
spudfan
Ireland
Laughing Thumbs Up 1982 88" 2.25 diesel
Post #724871 22nd Aug 2018 5:58pm
gilarion
When replacing a window seal most people use Fairy Liquid as a lubricant use instead WD40 it works much much better. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #724893 22nd Aug 2018 7:04pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
^ I can't tell if thats a prank like putting "WD40 on your brake disks makes your car go faster" as i'm pretty sure WD40 is corrosive to certain types of elastic seals. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #724897 22nd Aug 2018 7:12pm
gilarion
Quote:
^ I can't tell if thats a prank like putting "WD40 on your break disks makes your car go faster" as i'm pretty sure WD40 is corrosive to certain types of elastic seals.
According to their website, WD40 is safe to use on rubber so you have no worries about using it on that substance.
However, you may be correct in saying elastic may not be safe to use with WD40 as these days most elastic is not made from Latex anymore but from synthetic cores bound in polyester or nylon. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #724903 22nd Aug 2018 7:21pm
X4SKP
Post #724904 22nd Aug 2018 7:24pm
OsloBlue
Apologies for clarity i was referring to Rubber and latex with "elasticity" not Elastic fabric weave
i remember a four hour safety briefing on why we should only use silicone based lubricants on air seals after an access port seal was damaged by someone using WD40 on a hinge point. Apparently when the seal broke water pressed in and threw someone into a bulkhead at 30 odd MPH
http://www.ybw.com/forums/showthread.php?5...eat-rubber
But apparently WD40 have a silicone alternative for just this scenario.
https://www.eurocarparts.com/ecp/p/car-acc...gLQK_D_BwE I'm on IG: https://www.instagram.com/osloblue42/
Post #724914 22nd Aug 2018 7:50pm
Procta
My pal told a story about one of the lads I used to go to school with, putting WD40 on his brakes on his pedal bike, to stop the brakes squealing. My pal saw him go down one of the most steepest hills, Censored himself and jump off the bike. My pal just went in and made a brew. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #724930 22nd Aug 2018 8:44pm
