Home > Maintenance & Modifications > Broken Headlight |
or new lens and
Acrylic Headlight Guards STC7561 |
22nd Aug 2018 9:39am |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
Good point
I'll check them out, thanks |
22nd Aug 2018 9:58am |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Why dont you put the wipac crystals on. Plastic lens, better than the standard headlights. Put nightbreaker bulbs in and your sorted
Whilst you're there you could fit stainless steel bezels as well. |
22nd Aug 2018 12:21pm |
Got stainless bezels sat waiting
Will check those out too |
22nd Aug 2018 12:49pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
+1 for williamthedog's suggestion
Click image to enlarge With a boomslang loom they're bright even in daylight. |
22nd Aug 2018 2:01pm |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 456 |
Hi,
Are these a direct swap over, or is there any rewiring to do? Cheers all. |
22nd Aug 2018 3:52pm |
Easy direct swap - but as suggested above rusty bezels (the ring that holds the light unit to the headlamp bowl) can be a problem.
This is a good guide https://www.landyzone.co.uk/land-rover/headlight-renewal.130728/ |
22nd Aug 2018 4:02pm |
I have replaced the bezels with the stainless ones, so I will look into this. Cheers mate. |
22nd Aug 2018 4:07pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20487 |
If you change the bezels to SS get the SS fixing kit too. No Guts, No Glory.
22nd Aug 2018 5:35pm |
The standard wipac ones are cheap, they fitted the same ones (with a side light) on the mini, In 20 years and just shy of 100'000 miles I've only broken one on my mini.
I think you're just unlucky to break one. |
22nd Aug 2018 6:49pm |
I've had six Defenders without a windscreen or headlight needing replacing,
Number 7 and although my favourite it will of had both. Lucky Defender parts are cheap to replace 👍 |
22nd Aug 2018 7:07pm |
New headlight on and stainless surrounds fitted
I must say I prefer black surrounds so might get another set and get them painted. |
1st Sep 2018 5:58am |
Which headlights did you get after?
1st Sep 2018 6:30am |
I just replaced the one with standard wipac unit from Duckworths
For now. |
1st Sep 2018 7:02am |
