![]() | Home > In Car Electronics > C Tek recommendations |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
I have a CTEK 7.0 and keep it plugged on through a live 'cigarette'` lighter point all the time, as I do on all our modern cars.
It guarantees a good battery and CTEK have never let me down in years of using their products Thoroughly recommend. ![]() ![]() 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2539 ![]() ![]() ![]() |
I've had a couple of MXS 5.0 chargers for a number of years without problems. The problem with the XS 0.8 is that it is only a trickle charger and therefore not as versatile as the 5.0. If you ever need to charge a battery overnight in an emergency then you'll not achieve it with the 0.8. I know there's a large difference in price but I think if you only have one Ctek in your garage then it should be the 5.0 Defender 90XS SW
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 357 ![]() ![]() ![]() |
Thanks for the replies, it's not so much the price as I only want to buy once, but don't want to buy something oversized and physically larger than necessary for installing.
Looks like the MXS 5 is the way to go so far. Thanks Keith |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Hi there,
I have both chargers. There is little difference in physical size. I do not think the 0.8 would cope with a flat battery larger than the motorcycle size battery. It is more a trickle charger for larger batteries. Would recommend you get the 5.0 as it is far more versatile and would meet your needs. |
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 238 ![]() ![]() |
I have the MXS 10 £100 from Halfords when they have them on offer. I have it connected to a towing connector so that I can just plug it straight into the back of the 90 when its in the garage without any fuss
![]() Cant fault it, although it can be frustrating if you need to charge a particularly flat battery. |
The MXS 5.0 has a button giving you the choice to charge at 5Ah, or at only 0.8Ah. So with that one the charging speed is at your choice.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17729 ![]() ![]() ![]() |
I have a couple of MXS 5 chargers which are ideal for Defenders and similar sized batteries, and also an MXS 25 which I use for the humongous battery on my mobile crane. The latter would be massive overkill on a Defender battery but is ideal for a battery the size of a horse-trough.
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
I have an mxs5, perfect for general use! Also have an older xs7000 which is good for slightly faster charging.
Once my split charge is in I plan to replace my 7 pin socket with a 13pin, then will make a ctek to 13 pin adapter to go with it |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1647 ![]() ![]() |
ive ran a ctek 7000 for many years on my weekend motor.
the smaller one isn't man enough charge a agm battery.if you look on their webpage there are recommendations galore. https://www.optimabatteries.com/en-us/supp...rging-tips |
MXS 5.0 ordered.
Thanks Keith |
